'Fast' Rev Limiter - Link G4+
1816 Vistas
Hello all,
kindly see the below video ; would anyone in here know the configuration of the same ' fast bouncing ' rev limiter ?
[url=https://www.youtube.com/watch?v=wMjlJYdnV0A]https://www.youtube.com/watch?v=wMjlJYdnV0A
Many thanks
Not specific to that ecu but for something "tight" like that you want a very small rpm hysteresis setting on the limiter and a hard cut.
thats correct, do you know the configuration ?
bump
