FC Datalogit software
6531 Vistas
Hi all,
i'm trying to setup my new workshop computer and i have some issues getting my old power FC Datalogit software to work. Does anyone has this software still ? i tried contacting them on every single e-mail i could find , zero response. Any help would be appreciated a lot
Thanks
Kenny J
What engine application is it? It's a black box right, not a tan one? What version of Fc Edit are you using? Is it the software itself not loading or are you having trouble connecting to the ECU with usb serial converter?
Try this https://drive.google.com/file/d/0BzoEDgrFUehAQWdnUEpkaDdTcWs/view?usp=drivesdk
Install it and then overwrite the FC edit exe to get to version 1.129 . It's not the absolute latest but should hopefully work for you.
Is your unit registered with them? if so you should have access to the yahoo group. If not, email me evan@revdperformance.ca and ill send it to you.
i've tried to register my unit , paid the paypal link but they didnt respond at all.
currently got it working , thanks all!
