Few issues in the Dimemod 2015 STI
2502 Vistas
Hi guys,
I just got my car tuned with the dimemod patch and I'm having a few issues.
First, when the car's been sitting for a while, it hesitates to start right away.
Second, when the car is idling and I give it gas, the RPMs drop to 400-500 and then come back to normal.
I'm running map switching option in dimemod. Can you check my map and see if the injectors scaling is fine for 1050x injectors? Please let me know if there are any improvements that I can do for this.
and also I am trying to get the Launch Control working but haven't had any luck.
Here are the mods:
COBB SF intake
Grimspeed catted Downpipe
Indivia q300 catback exhaust
NGk 1step colder spark plugs
Cylinder 4 Cooling Mod
IAG AOR
Grimspeed 3port
Turbo smart external waste gauge 40mm (Comp-Gate40)
ID1050X injectors
AEM340 Fuel pump
Radium FPR kit
Competition stage2 clutch
Tune file and definition
  • STI_STG2_DM_91xF4_MR_ALS_F1.bin
The starting issue may be simply a loss of fuel pressure in the rail, that needs to be restored. Depending on your specific vehicle's setup, you may be able to monitor that, or hear the pump(s) building pressure when the ignition is turned on. Usually ECUs have a delay, such as 2 seconds, between the ignition turning on the pump and then cutting the pump is there is no crank signal, so try it a few times.
It's unlikely, and will usually show up as a different problem, but there may be slight leakage from one, or more, of the injectors, causing an over-rich (flooding) issue until cleared.
I agree with Gord, try keying on, waiting 3 seconds then start and see if fine when there's good fuel pressure at the injectors.
Off idle you're dealing with acceleration enrichment and the main VE table mostly. If the VE table is proper in steady state then adjust accel enrich.
thanks a lot guys. So, I found this loose FPR vacuum hose that was connected to the BOV hose. After I tightened it down, things got a lot better, but it still happens sometimes, especially if I haven't driven the car for a couple of hours.
Mike, what do you think? If I multiply the acceleration enrichment A and B tables by 5%, do you think that might help?
Accel enrich wouldn't have anything to do with the car failing to start. That would be down to airflow and cranking fuel mostly.
If the hose fits loose on the FPR, zip tying it may not seal it up so that could impact when you hit the throttle.
If you're sure everything is mechanically sound and all steady state tuning is accurate, then you can try adding or subtracting Tip in fuel and monitor wideband AFR vs. your intended AFR to see what's helping or hurting your situation.
Great, Thanks Mike. I will try that.
Sounds good, you're welcome!
Sourcing good quality vacuum hose locally can be tough in some areas. I don't know what part of Canada you're in, but JRP likely has some good stuff in the proper size.
