Fitting R35gtr coils
5563 Vistas
Wich dwell times do you guys use for R35 coils? Couldn't find any table...
Thanks.
Hey Marco,
My timing dwell table with R35 coils for the last 14 months.
[img="blob:https://www.hpacademy.com/f1c1e633-24e9-41c3-9088-356afc452af1" alt=""]
Michael, rekon you could post that table up as an attachment? I can't get that link to work :-).
Cheers.
Hey Zac,
I attached it also:
8V/8.7
9V/7.3
10V/6.0
11V/4.7
12V/3.9
13V/3.5
14V/3.2
15V/2.8
Hope that helps
Cheers!
Mike
Hey Mike,
thanks for your post, but this is just the raw data, i have that too, but in a Link G4+ you have to program dwell time depending on rpm, i calculatet a table, but that is a mix of base map values and raw data accepted as idle rpm values.
Your pic shows something different...
Regards.
