Ford Focus SE Bad Idle HP Tuners
2337 Vistas
Having difficulty dialing in the idle/ fuel. While under load above 1000rpm. It is a ford Focus SE. STFT runs at 38.3%. Any advice or tips would be greatly appreciated. Logs and tune attached.
  • 20-05-01-06-02-15.hpl
  • 2014-FOCUS-With-actual-vacuum.hpt
sorry for the delay sorry did you find the issue ?
