Fuel tech 450 crank and cam trigger error
4761 Vistas
Getting a error code on the fuel tech, need some assistance
we need more info to help here
when does this error come up
has it been running with out error and if it has how long
is it a new install
what does fuel techs help file say
Regards Ross
The car was working fine, just parked up a few days and went to start, idling and cut off, tried starting back and error codes came up. I suspect its the crank sensor itself so i am looking for one atm to try . It was strange as we didnt do anything with the car and it happened
Any update on this?
