getting lm2 lambda reading into hp tuners.
1813 Vistas
do i need to wire from side out on lm2 into hp tuners to get a lambda reading instead of from serial cable that plugs into he bottom outlet?
Hello not something i have personally done but here is a forum on the Hp tuners forum you will need to join the forum to be able to see it
https://forum.hptuners.com/showthread.php?29101-How-to-properly-wire-the-LM-2-to-MPVI-Pro
Regards Ross
