HALTECH 2JZ Base maps
4272 Vistas
Good evening/morning everyone,,,
Could anyone gives me his opinion about haltech 2jz base ignition and AFR target tables ? Can we consider them a very safe starting points ? I will run 95 fuel pump on my daily use driving and VP C16 on drag rolling race events.
note:
my setup
-stock internal block + 272 cams
-boost range [1- (2 as a maximum)] bar.
-62-69mm turbo
-1000cc fic injectors
thanks
