Haltech 500 and First time to tune inquires
4537 Vistas
Good day to you Collegues,
i have an inquiry regarding the ecu setup for first time, i am new to tuning and this is the first time i am going to tune the engine using standalone ecu ( Haltech platinum 500), let me first list my engine setup then i will go for the questions:
my setup is :
4efte toyota engine
FMIC 3" core
2.5" piping size
TD04L turbo ( wrx oem )
external wastegate ( tail 38mm Mvs)
COP ( 1uz vvti coils)
550 ev14 DW injectors
HKS fuel rail
tomei FPR
aftermarket air intake manifold + 70 mm throttle body
stock internal + cylinder head
target boost is 1.2 Bar
Project application : 100% offroad
i going to start this engine as my first time to use standlone ecu and little scare , i have set the main setup and every thing but i have little doubt about the load axis in the fuel and ignition main tables ( MAP) because i have 16x16 cells so,
1- what is the maximum vaccume value will be ( -60 or -80 .. etc) because i should use 16 cells to reach 220kpa of boost, i saw motec software and check its files which has start from 0 to 100 as NA engines and 0 to 100 and above 100 for boosted engines .
2-I would like to set up some engine protection for safety like IAT, ECT..etc but i couldn't find in haltech platinum 500
3- Regarding the compensation ( correction), should i disable the correction tables before starting to tune the base fuel and ignition maps? if not what should i do?
4- How to functional test the injectors and ignition coils individualy? or as group?
5- where to connect Aux rev limitter wire ?
6- i am connecting aftermarket RPM gauge, i connected the tacho wire to the signal wire which comes from the gauge ( it was green wire), should i put relay or fuse between these two wires or it will work fine in this setup? in haltech software i put 12v, pullup 50% and 4 cylinder
7- Engine rpm is 7500 as cutt-off rpm, i have set the rev limitter to 7500 and hard cut , ignition cut is this ture setup?
8- Decel fuel cut, i'd like to use this option but, can i use on/off switch to activate and de-activate this option?
thank you all in advanse and i wish do well after your kind support
Kind Regards
Khalifa
Ive a base map for a 4efte if u would like me to email u it , 1.6 bar on vf24 sard 550 injectors and 3 bar map sensor , u will need to fit a tps sensor also as the stock one is just a on off switch ,a tps off a rb26 fits almost straight on the stock t body , this map is for the stock dizy but I can change it if u like
Just reading ur last post I would go for a link G4+ if u have not got the Ecu all ready but the haltach works fine too
Dear Chrisccm,
If you send the file i would appriciate that, ( khalifa_alrayes@yahoo.com) i went for haltech 500 and i have another project which will have link ecu soon, i know the ep82 manual tranny TH its 0 and 5v on/off nothing in between which keep me struggling in tuning lo and hi maps in Apexi SAFC-ll last year.i hope i can find answers for my question mentioned to let my self implemt what i have gained from HPA courses
I appriciate your fast response dear
Regards
email sent man the file is on the last email I forgot to attach it in the first one lol
Thank you dear, i recieved your emaile
