Haltech ecu manager and ESP software playback rate Issue.
2912 Vistas
Hi,have a problem with ECU manager 1.14 also same issue with ESP 2.43 soft.i LOG all ECU Chanels in laptop , and save as external file.when open external file to playback on ECU MANAGER or ESP (to test and make corrections in fuel , ign....maps).Only work as expected "1rate". if i select 2rate, playback advance X2 speed, and if select the other options, 0,5rate,0,1rate.... also playback advance very quick... not slow.someone know what could do to solve issue? pleasemy laptop run windows 10.thanks
