Haltech Elite 1500 problem
1848 Vistas
Hello,
I have a Nissan S14 with Haltech Elite 1500. It's a new rebuilt engine and this is my first Haltech.
I managed to start with the map it had but throttle was not responding. Now I started a new map and it won't start at all. Or when it starts it idles under 500 and stalls.
The engine has 1000cc injectors, iat sensor, and haltech lambda controller.
Any help appreciated.
Regards
Have you confirmed timing with a timing light?
Can you post your map and a log?
Thanks
Seth
Wandering Gaijin Tuning
Hi Seth,
Check if the file will open please.
Didn't have the chance to check the timing since it only started for a few seconds. but tried in different positions with no effect.
No logs either
Regards
Mark
