Haltech Elite 2500 - 12 injectors
3712 Vistas
Hello
I am trying to work out if I can use 12 injectors on my Elite 2500 and below is what I am trying to do
First set is set up -- 6 outputs , Sequential , per cylinder
Second set is set up -- 2 outputs , multi-point , shared -all cylinders , injections per cycle 1
Both injector sets are Bosch 2200cc
I am not sure that this can be done but I am trying to get a second set of injectors to work without upgrading to Nexus or something else
Screenshots below are from my trial to get just the second set to be active while the first set is disconnected , I was able to get the car to idle close to 1.0 lambda when I had flow set to 6000 instead of 3000
And the flow is set to 3000 because of my high fuel pressure
Just got a confirmation from Haltech Australia that this can be done and Batch would be preferred
Flow rate of the second set should be the cumulative flow rate of the 3 injectors wired to that output
