Haltech elite 2500 launch control ?
3597 Vistas
So im planning on useing this feature in the haltech elite 2500. I notice i cant find a target boost, a two step rev limiter so you can bounce off before dumping the clutch. The elite 2500 uses a ignition map and a fuel enrichment map. Ive been watching the webinars, but the ones available are different then how the elite is setup to tune it. Ive tuned this feature on a aem series 2, and its similar to the information on this site, but i just dont know how to set these tables, and use a proper approach.
