Haltech knock control on individual cylinder
3043 Vistas
Hi guys
So I currently have an haltech Elite 2500 with two Bosch knock sensors installed on my 2j. The knock sensors are configured as Bank sensors for cylinders 1 through 6. I notice under the knock sensor tab there are two tables bank one long term trim for ignition and Bank two long-term trim for ignition. The problem is I can only apply to correction from the tab;Bank sensor 1 to the ignition table.how do I apply the correction from Bank Sensor 2 to the ignition table on individual cylinders? how do I also configure the knock sensors to monitor individual cylinders on the haltech elite 2500?
Sorry I don't know.
Haltechs dont do individual knock. Banked is the best you get with that...
Steve I would like to know if I choose Bank on the elite 2500 what what are the advantages and disadvantages?
Well if it knocks in a cylinder on the right bank, only the right bank will be retarded. Advantage is you wont loose as much power as if ALL cylinders was retarded. I dont see any disadvantage going banked.
Thanks steve
Hi,
Can I at least see what cylinder was knocking and add some fuel to it in correction table?
Thank you
