Haltech not reading manifold pressure
1907 Vistas
Hi
I have a elite 1500 with there p&p k20 harness on my supercharger k20 and it's not seeing any manifold pressure and stays at 0.0, I've loaded the haltech file for the sensor and assign the wire that they say to. When I pull the connector of the map sensor it stalls
Any ideas
This is what it set to
Is this a new problem (was working, now failed), or a new installation that has never worked?
That sensor calibration provides Manifold Gauge Pressure, instead of Manifold Absolute Pressure -- is that what you want? Have you confirmed the wiring from the ECU pin to MAP sensor signal pin? How about voltage and ground?
If I were to guess, I would bet that the setting "fuel load type" of Estimated MAP Sensor, causes it to use the throttle position. Can that be changed to MAP sensor?
Picture won't really help anyone figure out if you have something wrong in your configuration, you need to provide your calibration and a logged data file showing the problem.
Any update on this? We'd love to help you get it resolved.
