Got the car together and tried to get it running today after switching to sequential ignition and COP wasted spark. I have confirmed spark via the spark test. 1 and 4 fire on spark A and 2 and 3 for spark B. When it comes to the injectors it seems cylinder 2 and 4 aren’t firing. (Confirmed with temp gun on the cylinder and feeling the clicking on each injector with a screwdriver) Am I missing something? I clicked sequential injection, turned off the ecu and switched the jumpers inside the ecu on shown in the instructions and then power cycled the ecu. Car almost tries to run but just can't get there. I also have logs if that helps
The issue is fixed! Needed to select additional drivers in the settings menu and power cycle the ECU.
Good work Pranav!
This will be helpful for anyone else in the future with the same issue.
