Hondata target lambda table trouble
1933 Vistas
I cannot for the life of me get hondata's target lambda table to be different than the base set afr. Not that its needed but it would be nice to use the function more fully. the 3d map shows it drop way off the screen with any smaller number and wont return in the 3d map when set back to the base set afr. I do not tune very many turbo honda's. Would someone shed some light on this please.
I'm not sure I follow? Are you saying you can't edit the numbers in the target lambda table?
Thanks for the response andre. Yes that was my problem. The target table has a spread that you can configure but I found out they dont allow sections to be edited like other programs just left to right and the width of the spread it seems.
Have you try using other software to edit it?
