Honeywell PX3 Series Pressure sensors, any one used them?
3024 Vistas
Hi,
Has anyone use these in a motorsport application? Do they last ok?
They're almost half the price as the MLH series... thinking of grabbing some for coolant and fuel pressure.
[url=http://www.farnell.com/datasheets/2334678.pdf?_ga=2.30362943.1478425537.1589326814-855456946.1581300639]http://www.farnell.com/datasheets/2334678.pdf?_ga=2.30362943.1478425537.1589326814-855456946.1581300639
[url=https://au.mouser.com/ProductDetail/Honeywell/MIPAN2XX100PSAAX?qs=sGAEpiMZZMvhQj7WZhFIACqxHlobrjCqbzn%2F6rXBBheL3C%252BJJQ%252ByAg%3D%3D]https://au.mouser.com/ProductDetail/Honeywell/MIPAN2XX100PSAAX?qs=sGAEpiMZZMvhQj7WZhFIACqxHlobrjCqbzn%2F6rXBBheL3C%252BJJQ%252ByAg%3D%3D
I came across these guys recently - the new Honeywell MIP range, and grabbed a few of the 100psi sensors. I wouldn't bother with the px3 or even the MLH when u can get these now. Px3 isn't designed for fuel or coolant either. Only downside is the small range of options
Will check them out, thanks!
