how to make calibration on motec plm
2448 Vistas
hi
i buy motec plm with ntk sensors but iam try to make calibration but its field may i know the right setup
From the setup menu choose the sensor type as NTK. You can perform a free air calibration by selecting 'Calculate from O2 concentration' as the calibration method. Press calibrate, and send the configuration to the PLM.
