How to street tune ignition timing on FT450 without knock sensor?
1881 Vistas
So just as title states. How are people street tuning ignition timing or even getting remote tunes without a knock sensor? I ask because my friend recently swapped a 6g75 mivec in a 5g mirage for his all motor project. He bought FT450 but then realized it doesn't come with a knock sensor logging setup. For now it's going to be on 93 oct on street duty and probably switch to e85/90 or methanol at track. I know e85/90 or meth is less timing advanced sensitive compared to pump 93. I was thinking only solution is to buy something like a Tuner Nerd knock monitor or Plex setup.
Christian,
HPA's road tuning course includes a module on this specifically. Yes you'll need a way to monitor for knock.
https://www.hpacademy.com/dashboard/courses/road-tuning/
