HP tuners and LM2 Wideband controller setup questions.
2061 Vistas
I have a 12"hp windows 10 convertible tablet/laptop that has a single usb port. Does anyone know if there would be and issue using a usb splitter to hookup my HP tuners MPVI pro and innovative motorsports wideband 02 controller to use my small tuning laptop.
It 'should' work but in reality you'll just need to test it out. I've found in particular the LM2 is a little fussy about USB to serial adaptors which may also translate into some weirdness around a USB hub.
