Hugong TekMaster MIG 200
3000 Vistas
Hi everyone,
I’m looking to buy my first welder after gaining some experience with stick welding (MMA), and I’m currently considering the Hugong TekMaster MIG 200. It looks attractive because of its multi-process capabilities — MIG, Stick, and Lift TIG — all in one compact unit.
However, I’m still hesitant for two reasons:
  • It’s a Chinese-made machine, and I’m unsure about long-term reliability and build quality.
  • I’m not convinced that a machine designed to “do it all” can actually perform well in both TIG and MIG modes — especially for a beginner who wants to develop proper technique in both.
  • I would really appreciate feedback from people with hands-on experience using this machine (or similar ones). Does it live up to expectations? Are the TIG and MIG functions truly usable for learning and producing decent quality welds?
    Thanks in advance!
Most of the Welders that you see on the market are of Chinese origin.
Personal experience is that a All-in-one welder, especially on the lower end of the scale, doesn't do any of its functions particularly well, and you end up with poor performance.
It depends on what you are doing, TIG will usually give a better looking weld but is slower to do. MIG can look quite clean as well, if the settings are correct for the material. If you are looking at doing Allot welding, then TIG is the preferred option.
