Id1700x data input Haltech elite 2500
2087 Vistas
Wondering the proper way to input data from the elite tune file off injector dynamics website.
Currently just put in flow and dead times based on the older ps2000 table. The 2jzgte engine starts and runs.
wanting to possibly add second axis to these tables to get the most out of the injector.
here are the injector characterization tables:
http://help.injectordynamics.com/support/solutions/articles/4000075013-haltech
If there is a table file I could just load up or if someone cares to explain I would appreciate it!
-Jmar 2jzgte 04 tundra
Maybe I’m overthinking and just need to put the data in for the pressure I plan to run which would be 300kpa.
That's correct. They provide the different pressures because not everyone uses the same fuel pressure.
