ID2K injector alternatives?
1085 Vistas
Is there any injectors with a lower price of that size that works as good as the ID injectors?
Bosch over 1400cc is CNG as far as I can tell.
In my experience the ID2K leave nothing to be desired in idle or low load conditions.
Is the FIC stuff decent?
I haven't found something that works as well as ID injectors regardless of price to be honest.
The ID2000 is long discontinued now and the ID1750xds and ID2600xds are the closest current models.
They both work really well as secondaries and I use 1050xds or 1300xds as primaries.
If you're dealing with a drag race car and aren't as concerned about a high level of precision of fuel delivery at light loads, don't want to run a primary/secondary system, the 2600 is pretty easy to manage like the ID2000 was.
