Idle issues
2056 Vistas
hey guys I have an integra, 98 vtir model
it’s running a stock b18c2 head
b20b block
elderblock TB 70mm
440 injectors
and headers and an exhaust / intake
simple set up
I’ve done a stock b20 map to start with and have added fuel in areas necessary( 0 degree timing at the moment) , yet I have idle cut around 3K I’m running a hondata s300. Rev limits set to 7k for the time being and haven’t messed with idle air control settings
any ideas?
Can you explain what you mean by idle cut? Do you have a screenshot of a log showing it?
