Idle vs Main (Hi Octane) Spark Tables
1510 Vistas
It is said the GM ECU uses thresholds to bounce between the Base Idle and Main (Hi Octane?) spark tables based on a set of thresholds which I believe to be the following:
1. TPS or MPH > threshold = use Main Hi Octane Table
2. TPS and MPH < threshold = use base idle table
TPS < threshold and speed > threshold = use main Hi Octane Table
Does anyone know where these threshold tables are located on the GM E67 table sets?
not super familiar with this ECU but i don't think these threshold tables are adjustable in HP tuner software,
Understood. Not trying to adjust them, just trying to find them to see what the thresholds are.
