Ignition and injection 3d maps
2532 Vistas
Has anyone got any n/a 3d maps I can view and tables
I'm going over mine and it looks pretty rough it has been dyno mapped using a braked dyno but they failed To notice my high fuel pressure and I didn't see any kind of ignition checks ie knock seemed guess work I sat through entire session
Assuming VE based system?
Is it actually TPS based load or something else? It looks a bit odd. It would help if you can give more details on what exactly you are running.
What engine, ECU, and mods?
