Injector Deadtime Bosch E46 M3
2967 Vistas
Hi Guys! Can someone please give me the injector deadtime table for the 0 280 156 052 Bosch injector? (Stock BMW E46 M3, S54 engine) Thanks in advance!!
If you can't find that info or test it yourself (see this thread for some ideas) then you might try some common values that work with many injectors. Start with about 0.9 - 1.0 mS at 13.2 volts, increase the deadtime about 0.15mS for each volt drop.
If you have this wrong, the it just means you will "bake in" any errors into your fuel map or compensation tables.
