INJECTOR DEADTIME VS FUEL PRESSURE
2806 Vistas
I HAVE A STOCK H23AVTEC TO TUNE AND IM INCREASING THE FUEL PRESSURE FROM 45PSI TO 52PSI, DOES MY INJECTOR DEADTIME NEED TO BE CHANGED AS WELL AND IF SO HOW DO I CALCULATE THAT
Injectors dead time also needs to be adjusted but for how much is the question of particular product. Nirmally this information comes with injectors from manufacturer as it can be seen in the file attached ( in this case it is for Bosch 980 cc injectors).
this helps. ill use this as a base table to configure the increase in deadtime with increase in fuel pressure using my stock injector deadtime and see how it reacts. this has to be so because i havent gotten any exact information as such from honda concerning stock fuel injector data.
