Injector Latency R35 Nissan GTR OEM on AtomG4X
1374 Vistas
Hello
Nobody in the Linkecu Forum has the answer for this question, hence I ask here:
Can you provide me with the latency / deadtime values on stock Nissan R35 injectors?
I believe they are 580cc, but not 100% sure.
The numbers on the injector body is this:
Denso 9JDEJ : 105093019
Thank you in advance
PS: I am aware of the fact that this is not an ECU specific question.
