Innovate LM2 analog outputs
2459 Vistas
Hello all,
the innovate lm2 manual states that the two analog outputs can be used for sensors 1&2 respectively.
Sadly I've tried programming but no luck with this.
I have the dual channel kit with all bells and whistles
in the programmer software I'm not able to select sensor 2 (it's greyed out), anyone experience this?
My firmware is the latest
on the LM2 it does show correctly with either or both lambda(s) connected, I just can't get it to output on analog out2
analog output 1 functions fine.
if anyone has solved this, please do the "fix-and-tell"
Sorry I don't think I've ever tried to use both analogue outputs. For an enquiry of this nature I'd suggest contacting Innovate directly.
