Installing additional temp knock sensor on 3sgte
1668 Vistas
I've just ordered a tuner nerd knock monitor kit and was wonder if someone could tell me the best place to install the sensor on a REV 3 3SGTE? Ideally I don't want to remove the sensor I have in the standard location as I want to compare the 2 logs so would be looking at fitting the TN one somewhere else just while tuning.
