Is injector data available for the Bosch EV14 injectors?
7041 Vistas
I'm currently in the process of picking a fuel system for my RX-7 FD3S, and my first choice was to go for Injector Dynamics, since they have all the injector data I need for tuning the car. However, the price of these injectors (especially the 2000cc) is quite high, so I was looking at other injectors, and a few people recommended me Bosch EV14 injectors. I am quite uncertain if there is adequate data available for these injectors. I remember a while ago I was looking at Bosch EV14 2000 cc injectors, and they also had a sheet with injector dead times and flow numbers, and even claimed these were matched from the factory.
I'd like to know what you guys think, do you know of any good alternatives I could look at? Is there a source for finding the injector data of the EV14 injectors?
I would suggest you check out FiveO Motorsport
I linked you to a search for 2000cc injectors. They have been able to supply injector flow data and deadtimes for anything I've purchased from them.
I would contact them about the Bosch EV14 2000cc injectors (they shows the Bosch EV14 1000cc model).
Thanks David!
I guess, in this case, its up to the reseller to measure and provide the data? So Bosch doesn't provide it?
