JDM SF5 ECU cross compatibility
2617 Vistas
Hey guys,
Was hoping some of you Subaru savy guys could help me out. Customer has a 2001 SF5 Forester and wants a full PNP stand alone. IE Haltech/Link etc. I am wandering if anyone knows if there is a compatible WRX/STI ECU model since they are typically listed under WRX/STI. Still digging up SF5 pinouts to do a comparison....so not being lazy totally.
Thanks Guys
hello check on the Link website the forester will run the same plug as one of the wrx ecus they have the picture of the header plug will show which one is compatible and I think they also list the forester in the (this will fit section ) product info
the full pinout is in the g4x software
Ross
