Job Opportunity
1890 Vistas
Not sure where this should be posted so I'll try here.
I've learned of a job opportunity for someone interested in ECU tuning. Would be an entry level position, providing tuning and tech support for an ECU manufacturer in Cincinnati, OH. Would require relocation to that area, if not in the general area already.
Their ECU's are used in motorsports, motorcycles and RPV aircraft. Job would involve hands on and some travel.
Drop me a pm or email and I'll put you in touch with the right person
Paul Proefrock
contact me 2034340064
the manufacturer has posted an on-line datasheet for the position. I've attached the PDF and linked below. Performance Electronics
http://pe-ltd.com/assets/InsideSales-5-4-18.pdf
  • InsideSales-5-4-18.pdf
