Knock Detonation Set
2153 Vistas
Hi,
Is better that to use the Headset with knock detonation set or it's enough to use the ECU (AEM or G4 ECU link" data log graph to see the knocking?
- does the knock detonation set with headset will add value or I can catch the single knock with ECU data log and it's enough or the detonation set is more accurate?
I am thinking to buy knock detonation set.
Thanks!
I recommend always confirming the knock control configuration in the ECU by using audio knock detection with a head set. It's easy to have your knock setup wrong and either pick up false knock, or even worse, not detect knock that is occurring.
