Knock sensor for Gen 1 Small Block Chev
2221 Vistas
Just interested in thoughts on where the best location for a knock sensor would be and the style of sensor cheers
I'd be looking for any suitable threaded bosses along the sides of the block near to the deck surface of the block. If you're limited for choice then you could always share an engine mount bolt hole.
