Knock sensor(s) calibration or validation
1365 Vistas
Hi all,
is there any safely area or range ( load and AFR) ( Ex. low load lean AFR?) would able to artificially create knock for aftermarket calibration or validate stock knock sensor(s)?
Thanks
Steven Tsai
If you want artificial knock then use a hammer or wrench on the block. I don't think this will help you calibrate, but you can see if the sensors are responding.
I think what you want to do it measure actual knock safely. Here is webinar that demonstrates doing that on the dyno - go to 22:00 into that video to see the demonstration.
https://www.hpacademy.com/previous-webinars/049-setting-up-knock-control-link-g4-vipec/
Okay thanks! Much appreciated!
