kpro
2019 Vistas
how lambda targets are set in hondata kpro Ecu?
To learn how this works with the Honda ECU, you should read this section of the Kmanager Help/Manual:
https://www.hondata.com/help/kmanager/index.html?closed_loop_advanced.htm
