Laptop Wifi/Ethernet combo issue
1697 Vistas
Hi Guys,
Just got a new Lenovo p52s and have come across a strange issue I have not had before. If I'm using the internet (wifi) then plug into an ecu or other Ethernet devices, the internet won't work. Clearly, the laptop is trying to use this as an internet gateway rather than the wifi. Has anyone come across this before or any ideas on how to fix it? Its a real pain.
Jack
Hey Jack, that ids a weird one. It's almost certainly going to be related to your network settings but I'm not sure exactly what settings need to be changed to prioritise wifi over ethernet for internet connectivity.
