Large camshaft ls webinar
1734 Vistas
Hey guys just wondering if doing a large cammed ls based engine (e38 would be awesome) webinar is on the cards? I know alot of people have trouble with idle and low down drivability of these such set ups and I'm sure it would attract a large audiance. Also 6l80e tuning
+1 for a large cam LS idle tuning and drivability webinar/worked example. Currently struggling with this myself. Would be good to know how to determine at what point to abandon MAF and go speed density due to the overlap on the cam, etc.
Yes absolutely. We're planning a cam swap in our VE commodore with the L98 engine and will be covering this in webinar and a worked example. I can't promise when that will be though as we're currently filming some engine build worked examples.
