Leaded Gas / What type of gas to use?
2102 Vistas
I have a 1.5 JZ motor (2j bottom end / 1j head). I have had it tuned by a "professional" and I am running about 560HP.
Specs
1.5 bar
stock ignition
ngk bkr7e plugs (tight gap can't remember exactly how much, but tight)
stock coilpack
hks twin power ignition
850cc injectors
bosch 044 pump (stock lines / in stock tank )
garett gt35 turbo
aem ems v1
gas 110 Leaded
Question:
1. I was just told that running leaded gas will fry my 02 sensor. I haven't had any issues so far, so I am just wondering the validity of this statement.
2. If this statement is true, than what would you suggest type of fuel to run on my car given the above specs.
