Link ECU
2179 Vistas
Hi , is it possible to connect to the link ecu wirelessly?
Maybe using a usb wifi hub that sends and receives data? Or something else of you have come up to?
I want to be able to change things during the race down the track like telemetry but really dont know if this is able to be done.
Any ideas?
I haven't seen this done to date. I haven't had any experience with a usb wifi hub but my immediate concern would be getting sufficient range for it to be useful. Proper telemetry systems use either VHF or 4G modems to transmit and receive which provide the required bandwidth and range. If you do pursue this path please let us know.
Thanks Andre, i will try it and let you know. :)
