Hello,
I want to know how can i connect the innovate MTX-L Plus to Link G4+ Monsoon ecu(wiring) and what is the configuration i need to do in table to make it work .
Thanks
Normally, I'd wire these in through an analogue input and link in the sensor earth.
Set it as Lambda 1 and select the Innovate LC-1 calibration
the yellow wire to analogue input and the the black to ecu earth
