Link G4+ Xtreme Idle Setup
2452 Vistas
I paid to have my ECU wired in to my LS3 with LS2 e-throttle.
They set the idle speed control to Open Loop Sol/Stepper. Surely it should have been set to Open Loop E-Throttle? Or am i missing something completely?
Due to the LS3 having e-throttle, it doesnt have an idle stepper...
Can you post up your configuration file? But yes, I would have thought it'd be using the throttle for idle control.
Hi Zac,
Config attached.
  • RX7-LS3-Twin-Turbo-26-04-2018.pclr
You are right, your map has been set up wrong so idle speed control wont work at all. It need to be in one of the two E-throttle modes.
Thanks Adam!
I thought that might be the case as it wasn't doing anything at all when i was changing the settings, but when turning it onto e-throttle it started moving the throttle plate.
