Link G4x evo 6 no trigger 1 no signal
1084 Vistas
Hi Team,
I am unable to get a crank signal, looks ok in trigger scope. Have tried 12v and 5v pull up on and off. Standard 2 blade trigger wheel and sensor. Am getting signal on trigger 2 cam angle.
Are you sure that the Triggers->Trigger Setup ->Trigger Mode is set to "Mitsubishi Evo 1-6"? Your scope shows the signal look to be correct, but if it's not being interpreted correctly (so that Engine Speed, Engine Cycle Count, etc don't update) this usually means the mode is incorrect.
Hi, thanks for the reply. Yes trigger mode is set to evo 1-6
