Link g4x .rb26
1813 Vistas
Hello
Wiring link g4x to an rb26 with full APR trigger kit.
So , first
Does rb26 COP coils has internal igniter or I need an external one to run will link g4x.
Thank you
Noticed The IB wire goes directly to the OEM ecu with no external igniter.
Anyone can confirm ?
And what dwell can run in these coils stock rb26
The RB26 has dumb coils with a 6 channel ignitor, towards the back of the cyl head, in the coil cover. The dwell times in our GTR base map generally work fine with the stock coils.
