Link thunder
2228 Vistas
so its coming down to buying ecu a link thunder at this stage but if some one can tell me a better ecu for the drag / street car i would like to here why or what issues any one had with the thunder
what mods i have
built 2jzgte g42 turbo twin gate etc
sensors ill be running be air , oil, turbo speed,fuel, egts via can, wheel speed and abs sensors for traction the norm for any car really
Dbw throttle
gear box is a built th400
so i would like some feed back on peoples experinces i have had nothing but good things when i had a vipec v88 on one of my old cars
I don't think you could go wrong with the Thunder. It's a very full featured ECU for the price point and has more than enough functionality for what you're doing. The only thing I'd suggest you check is the max frequency on the digital inputs. I believe this was addressed on the Thunder but previous G4+ ECUs had a max frequency of 500 Hz on the DI inputs which is insufficient for turbo speed.
Yes the Thunder has differential Digital inputs which reads up to 6500hz, which will be fine for most turbo speed sensors.
I can highly recommend it.
