logging
2188 Vistas
my question is can you overlay logs on a link g4+ eg overlaying two wheel speed runs / thanks Dwayne.
You sure can. Open the log files you want to overlay. On the left side of the screen you will see a pop out box called 'Log File Manager'. You can then select the logs you want to overlay by clicking on the box beside the log. This will display both logs together on the screen and you can align them however you need by dragging the time stamp on the lower axis.
