ls1 knock sensor calibrations
1179 Vistas
hey got some stupid questions that I'm curious about, I was looking at the American factory tune files and the knock sensor tip in and rpm vs cyl air mass tables off the same pcm as well as OS as the vz ls1 that I have, is there a reason why the American knock sensor settings are way more de-sensitized compared to the Australian versions?
